[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4752: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4754: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4755: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4756: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
Dynamic MiNi Collective • View topic - new here
new here
Re: new here
Postby Joakwin » Thu May 05, 2016 2:30 pm
my dad gave me a zf 5speed, s-42, rated at 420 tq, monster trans, going to stick it behind a 2001 lm7 5.3 v8
and I started to work on the rear suspension
building a tri 3 link and im not sure if the set up will need a pan hard bar or not
the lower link arms are made out of 2x3-3/16 square stock, nice and heavy duty and if I bagged the truck the link arms are already set up for the most part for air bags
the crossmember is getting cut out because its in the way of the link bars
Joakwin
Re: new here
Postby Joakwin » Wed Jul 27, 2016 6:40 pm
this is how the frame sits now, a few more things to do before I can get the shell back on the frame
this up coming weekend I plan to fit the engine/trans to the frame, I have to make motor mounts and a trans crossmember
Joakwin
Re: new here
Postby Joakwin » Sun Aug 28, 2016 6:35 am
Joakwin
Re: new here
Postby 66Cooper » Mon Sep 19, 2016 10:38 pm
I just want you to know that some of us are coming back and checking the progress on your project. Unlike Facebook where it is a click to like each post, I kind of forget to leave a comment or say something. Love what you are doing!
Barney
Associate Broker Lauer Realty Tucson AZ
Buying or Selling Real Estate in Southern Arizona? Contact me.
BRG/W Classic Mini, 1275, 12" SAXONs
'04 EB S, B&B exh., 15% pulley, K&N Typhoon, M7 STB
66Cooper
DMC Treasurer
DMC Treasurer
Re: new here
Postby Joakwin » Thu Oct 13, 2016 3:22 am
I had left hip surgery on the 29th of sept
So the projects are kind of on hold for a little bit of time
But I did buy another set of cerwin vega pro audio speakers, 12's with horns
And found a geo metro to use as a donor car for the Lhd mini
Just have to figure out how I'm going to get the metro out to tucson from San Diego
So I can pull the motor and bring the mini back home but that will probably be early next summer when the subframe is ready
I have a few extra mini front subframes to use for the 3 cylinder build
Joakwin
Re: new here
Postby Joakwin » Mon Dec 19, 2016 5:22 pm
i got David's mini a few weeks ago, my daily mk4 golf broke something and dumped the engine oil while I was driving the car
car needs a new motor and so I saw this mini come up for sale and it looked pretty nice and drove sweet and so I picked it up
im in the middle of rebuilding the stereo system in the car
it has a dual amp and two sony 8 inch woofers,
im going to keep the sony 8's for now
and the dual amp will be changed out for some JBL amps
a mono block and a 2ch amp for the front door speakers,
and I plan to change out the stock door speakers for some jbl comps soon
Joakwin
Re: new here
Postby JPMINITUCSON » Mon Dec 19, 2016 5:39 pm
Sweet!
Jon
'81 Aussie Moke Californian
'61 Morris Mini-Minor
'71 Cooper 'S' MKIII
'76 Mini 1000
'13 MINI Cooper
JPMINITUCSON
Re: new here
Postby Joakwin » Mon Dec 19, 2016 5:46 pm
sony 8's in the old box
and the new box that im currently working on, .95 sealed before subs, good amount of air space
the amp I have is a jbl gto 301.1, 300watts @2ohms
while I was making this box one of my router bits broke, and it left two low spots in the wood, so I will build that back up and smooth it out before I carpet the box
im going to pick up some carpet today at lunch time and install it tonight
Joakwin
Re: new here
Postby Joakwin » Tue Dec 20, 2016 4:36 am
Put the carpet on the box tonight, tomorrow I will install some speaker wire
Into the box and seal it in and then drop the subs in
Joakwin
Re: new here
Postby Joakwin » Mon Dec 26, 2016 5:46 am
I got one of the jbl amps installed in the r53 tonight, going to work on the jbl 6.5 comps tomorrow, I already made some mdf speaker adapters rings for the door panels
i have the Sony 8 inch woofers installed with the temp amp, the new box is way better and hit deeper, but that amp doesn't push the subs the way they should be, but the new jbl amp will just fine
Joakwin
Re: new here
Postby Joakwin » Thu Dec 29, 2016 2:49 am
Joakwin
Re: new here
Postby Joakwin » Thu Dec 29, 2016 2:56 am
Stereo upgrades in the mini
Jbl sub amp, jbl door speaker amp, jbl door speakers, temp Sony subs
Joakwin
Re: new here
Postby Joakwin » Sat Dec 30, 2017 6:35 pm
by , on Flickr
mini has been turned into a automatic now
Joakwin
Re: new here
Postby Joakwin » Mon Feb 19, 2018 4:50 pm
by , on Flickr
rear disc brake bracket
Joakwin
Previous
Users browsing this forum: No registered users and 18 guests
