Mini Ad
Posted:
Thu Dec 11, 2008 5:58 pm
by Sanbient
Posted:
Thu Dec 11, 2008 10:35 pm
by th3118
Has anybody really tried it? Does it work?
Posted:
Fri Dec 12, 2008 12:34 am
by Luckiee's Son
I was gonna try it cause I have a webcam, but I went to the website to download the software and I can't read where to click to download...
Posted:
Fri Dec 12, 2008 4:55 am
by It Works
Luckiee's Son wrote:I was gonna try it cause I have a webcam, but I went to the website to download the software and I can't read where to click to download...
You mean you can't read German? I thought it was a requirement to take a foreign language in HS. What'd you take? Pig Latin?
(Marcus could point you to the correct spot)
Posted:
Fri Dec 12, 2008 6:09 am
by Louie B.
It Works wrote:Luckiee's Son wrote:I was gonna try it cause I have a webcam, but I went to the website to download the software and I can't read where to click to download...
I convinced my counciler that electronics was a foreign language
OK, sorry, back on topic.
Posted:
Fri Dec 12, 2008 8:18 am
by Gottoon
First, There isn't a download link...The site is only installing a plugin to make it work. I believe the issue of it not downloading is being caused by not having the proper language pack installed or a pop-up blocker keeping the install from running. I was able to get it to install on my Vista with the language pack installed but I am on a beta version of IE8 here at home and it would not let the website load after the install, even using compatibility mode on the site.
I will attempt to run this on my multi-language XP test system at work tomorrow and let you all know. I will take screen shots of the results if it works.
Posted:
Fri Dec 12, 2008 6:06 pm
by Sanbient
Here are system requirements to view..
Systemvorraussetzungen:
Internet Explorer 6 oder h
Posted:
Fri Dec 12, 2008 7:30 pm
by wearlaz
th3118 wrote:Has anybody really tried it? Does it work?
Yep - works pretty good! You need a good/fast connection though as it's using the graphics in the printout as input to the 3D engine.
Posted:
Fri Dec 12, 2008 10:57 pm
by Luckiee's Son
1. I'm not in HS. I'm in JHS.
2. I just happen to be an EXPERT in Ig-Pay Atin-Lay.
