DONT EVER forget the following
check your oil once a month
make sure your lugs on your tires are at 90lbs with a torque wrench
check your radiator fluid before and after a long trip
check your oil.....
if you dont...you'll end up with spun bearings, lost lugs to be found in front of justins driveway and a generally unhappy car.
stay safe! and dont forget....
...the DSC button is your enemy!
check your oil.....
